Lidar Lite v3 help needed
I’m doing some off-season learning and my focus right now is getting our Lidar to work. I’ve been able to get the Lidar working with an arduino, but the behavior is weird when trying to get it to work with the rio. For wiring, the Lidar is getting power and ground from DIO 0, and the I2C leads are hooked up to the “onboard” I2C port on the rio. They are able to communicate. I tested it by having the the rio tell the Lidar to take a measurement and then holding my phone camera up to the Lidar, and it shows the Lidar pulsing as the rio tells it to. The problem is receiving the measurement. It only returns “1285”. I can wave my hand over it and move it around, but the value is unchanging.
For troubleshooting I’ve tried adding and removing pullup resistors as well as checking the registries that I’m writing to, but nothing changes. I’ve added and removed various delays in the code. I’ve scrolled through tons of other Chief Delphi posts, Lidar documentation, FRC I2C documentation, and Github repositories but nothing fixes it. I’ve only seen one other person with the exact same problem (here), but their only solution was to switch to PWM. I’ve had it work with PWM, but the values fluctuated substantially (±3in).
Here is the code that I currently have:
package org.usfirst.frc.team3603.robot;
import edu.wpi.first.wpilibj.I2C;
import edu.wpi.first.wpilibj.Timer;
	I2C lidar = new I2C(I2C.Port.kOnboard, 0x62);//Create the I2C object with the onboard port and address 0x62
	@Override
	public void robotInit() {
	@Override
		byte] data = new byte[2];//Create a buffer to store the data
		lidar.write(0x00, 0x04);//Tell the LIDAR to take a measurement (write 0x04 to 0x00)
		Timer.delay(0.1);//Let the LIDAR take its measurement
		lidar.read(0x8f, 2, data);//Read the two measurement bytes
		System.out.println(data[0] + " " + data[1]);//Print the raw data
		System.out.println((int)Integer.toUnsignedLong(data[0] << 8) + Byte.toUnsignedInt(data[1]));//Print the processed data
		Timer.delay(1);//Wait 1 second
Any help is appreciated!
