LIDAR Sensor has arrived!
Just wanted to share that a new LIDAR (laser radar/rangefinder) is out on the market from “PulsedLight3D” for $90 – Class I laser so it’s FIRST legal. Just arrived today in the mail, and I hooked it up to my Arduino:
Did some initial testing via I2C, seems to be very accurate between ~20cm and 650cm (as far as I could test it tonight without finding a larger room), 0.5 deg beam width
Here’s a snapshot of my Serial output with distance in cm (~100 Hz samples averaged and output at 5 Hz), sitting on my desk facing up to the ceiling.
http://pulsedlight3d.com/
We’re going to have fun with this!
We got ours today as well. Similar results to your tests. Very excited about this little guy.
Being a geospatial geek, this is TOTALLY COOL!!!
This might be a newbie question, but this can be connected to the robo-rio via the I2C and programmed in labview to give us the distance. Right. I haven’t done much work dealing with I2C and am not sure what to expect.::rtm::
The sensor has 2 output formats: I2C and PWM. I have tested via I2C and it works great. To use PWM, you’d need to create a low-pass filter to smooth the output which could then be read by the roboRio analog input.
I will be coding up a Java Class this week to interface with I2C on the roboRio, which I’d be happy to share.
In case anyone is interested, I wrote up a java class for this, you can use the start/stop functions to use the built in updater Timer, or use the update function to only poll distance when needed.
LIDAR.java
Ordered! I have been drooling over this for 6 months. And we might have a use for it. I was going to buy it for my self regardless. If it works out I will get one for the team so we have two.
Based on the datasheet it seems this wouldn’t work on polycarbonate, since it transmittance is just as high at 905nm as it is in the visible spectrum, and the laser would mostly go right through. I really don’t know much about LIDAR systems, so does anyone else with more experience know if this would be the case?
I asked this question on their forum.
https://groups.google.com/forum/#!forum/pulsedlight3d
Polycarbonate doesn’t have 100% transmittance for near IR, but it’s still very high. You will get a small amplitude return from polycarb, which will be higher if there are scratches or dirt on the surface, or if you are getting specular returns from other light sources. You can configure the LIDAR-Lite to present either the strongest, first, or last return to you, and I’d expect whatever is behind the panel to be the strongest return the vast majority of the time (but not always).
Experientially, LIDAR sucks for detecting transparent objects and requires lots of signal processing and integration of multiple scans over time to have any chance of accurately detecting a transparent object.
FYI, I have detected distance to transparent windows with moderate levels of success. I’d assume polycarbonate behaves similarly, but would have to do more testing. We are programming up the LIDAR against the roboRio tonight so I’ll try it out.
For those that have these sensors, what is the jitter on the returned distance value you are receiving for a given period of time?
Does the returned value go unstable at any point in operation (i.e bouncing around different values) or is it pretty accurate, to what level of accuracy have you noticed? (i.e +/- 1 cm)?
Are you using the RoboRio or other embedded device to power and read the sensor?
Thanks for your response.
Thanks,
Kevin
Not quite. Glass is actually opaque to IR light, just like a piece of metal would be, while polycarbonate behaves just the same as it would in the visible spectrum (for a good bit). Things change when you move to different wave lengths, like, for instance, a black trash bag is totally transparent.
True for some IR bands but not near-infrared. Glass transparency doesn’t drop off until approx 2000nm but this laser operates at 900nm.
One source:
http://www.molalla.net/members/leeper/transmis.png
Fair enough, then I’m curious how the LIDAR is operating as well as it does. Interesting.
From the products google groups
https://groups.google.com/forum/#!topic/pulsedlight3d/ebRaHl6sylM
Paul,
That’s very exciting… in the course of looking at the forum I found Innovation First International… I grew up fairly near Greenville, TX. Will be joining the forum to follow along… have been getting into ROS.org and robotics in my hobby-time.
@Polycarbonate - the way the sensor acquires readings is by sending a bunch of pulses out and then capturing what comes back, combining those into a “correlation record” and then measuring the distance between the crossing point in the reference signal and the next strongest signal (or if you ask for it, the second strongest).
There are a few surfaces and conditions it can’t “see” but in my experimental experience it can detect most surfaces from one angle or another. Sometimes with reflective and clear surfaces you can get unexpected results, but that’s where that second reference comes in handy. You can use it to see a reflection or an object on the far side of a clear object if you are picking up your strongest signal from the clear object.
Pg. 17 “Signal Acquisition process” through pg 22 “Processing” of our manual goes into detail about how the sensor records information: http://pulsedlight3d.com/pages/docs
Let me know if you have any more questions very happy to help! We’re excited about what the chiefdelphi.com community is going to do with LIDAR-Lite!
  • Austin
tech2077, are you having any luck with this code? When I attempt to run I get zero distance data. Also, the i2c.read() function returned “true” (aborted). I’m passing in Port.kOnBoard and the sensor is plugged into the I2C port on the roboRio
Strange, it has worked for me. I’ve been using the mxp port so far, so I’ll test with the on board one.
Right now it seems that only the MXP port is supported with the LIDAR, I’m still investigating, but using the same power source and code, only the MXP I2C port will return data.
Dimensions: 21 X 48.3 X 35.5 mm
• Performance: Range: 0-40m Laser Emitter
• Accuracy: +/- 0.025m
• Power: 5vdc, <100ma
• Acquisition Time: < 0.02 sec
• Rep Rate: 1-100Hz
• Interface: I2C or PWM
•Max Operating Temp.: 70° C
•Eye safe, laser hazard free
Works up to 40 m, + or - 2.5 cm, <20 ms acquisition time.
We have ordered one.
