thanks, just pm me in chief delphi when you are ready to order. i’m in williamsport pa. i’ll gladly pay for shipping.
How are you calculating your numbers? What is your requirement? Before you continue to keep looking at motors and batteries, you have to start with a set of requirements to point your research in the right direction. Until you list out the requirements, we can’t really help you solve your problem.
You said the car has to go to 60 mph, but how long does it need to travel at that speed? What is the acceleration required? How many stop-start cycles will be required? What is the vehicle weight constraint? How many wheels will there be?
Devyash
You need to study up on the various types of motors available (DC, AC) and the advantages and disadvantages of each type. You then need to study the types of controllers available for each type of motor. Since you are aiming at maximum efficiency, you will have to select the motor and controller very carefully. As Tim above says, you need to have clear specifications for what you are trying to do before you start.
Adding regenerative braking will roughly double the complexity of your controller. It will also roughly double the losses in your controller while transferring power from the battery to the motor, reducing your overall efficiency. Unfortunately, I have yet to find a commercially available AC or DC motor controller for EV applications that has regenerative braking.
hobbyking brushless motors are grossly over spec’ed. the wattage they give is just stall current times maximum voltage.
It’s not overspec’d, just deceptive. It’s max input wattage instead of max mechanical output power
I got two “3000 watt” HK Sk3 motors for an gokart.
Any good ways to find the max mechanical output power?
Put it on a dynamometer?
If you know the stall torque and the free speed, and you believe the speed vs torque is linear, then the max output mechanical power in watts is stall torque times free speed divided by 4 (if using SI units).
I completely agree. I was planning on using Brushless (AC) motors because they are a tad more efficient and because there are no brushes that wear out over time. The only stress is the bearings, and using something like a ball bearing could last quite a long time.
This is the reason why I do not like HK motors. They do not give what they say. Also, I think that their motors are meant for high RPM, not high torque. That would also mean that the bearings have a whole greater load to withstand. Our BAG motors on our shooter keep failing because the motors can get up to 14,000 RPM Also, the motors are ridiculously priced (the ones that seam that they might work)
Anyways, does anyone know where I could buy a car motor? I do not want to use CIMs because they overheat after continuous usage, and they just do not provide the torque required
How are your BAG motors reaching 40krpm?
Darn It! Typo. 14,000. Let me edit the post above
go to a “u pull it”
find a prius
extract motor?
this would be the motor to use if you are doing what i think you are doing.
That seems like a legit motor. Also, is it advisable for me to use two motors, one controlling each side of the car? If so, that would allow easier computer control of the car. Also, I am planning to implement an autopilot routine, (in the future years), to just follow the roads straight and automatically stop and start in traffic jams. The following will probably use a camera and the stopping will be done either with a ping or a laser rangefinder.
Hey, can someone post about how safe/unsafe these batteries are against AGM/FLA/VRLA (Lead Acid) bateries? I do not want this car that I am building be a bomb in ceratin cases!::ouch::
Living in the middle of Arizona, a desert, I am probably unlikely to find Snowmobile Designers?
:deadhorse:
You can find them in some unlikely places (though I admit that I don’t see any registered teams from anywhere south of Illinois). And remember, there’s this wonderful invention called the Internet, which can help you connect with folks who actually have winter. (As a matter of fact, I remember having a couple of folks from Arizona on my Aero team–which worked in the same room as the Snowmobile team–during my final year of college in South Dakota, one of whom may have graduated from your FRC team–I can never keep 1164 and 1165 straight.)
As far as safety, AFAIK, they’re pretty comparable as long as you don’t do anything utterly stupid. The risk of flammability is a bit higher, but not nearly as bad as LiPOs. If you’re shipping them, you have to have someone who’s registered to do that, though I don’t think that’ll be too big of an issue if you’re not shipping them. Charging is more of common sense–use the right charger, and make sure it stops when it needs to.
There are quite a few people out there who have been building electric cars for a long time. Many of them are members of the EAA (I gave you the link in my first post in this thread). You are best to start by getting in touch with a bunch of them in your area.
how big is this car? are we talking go kart size or like a actual car size.
assuming you construct the pack correctly, as long as you don’t draw more amps than the cells “c” rating or discharge the cells below 2.8v you shouldn’t have problems.
I am thinking a little bigger than a a go-kart, but way smaller than a regular cart. that is the project, basically. that way, the car will be small enough to drive even inside a building :D!::ouch::
Hey, before, I was looking at Howell batteries because of their price. After doing a couple hours more of research, I came upon Winston Batteries (LiFeYPO4 instead of LiFePO4). Does anyone have experience with these batteries or this manufacturer?
Also, where can I buy these for the best possible price?
