Lightswitches
Rule <92> states that you can use any household lightswitch that fits into a lightswitch box at home… I’m having a little trouble interpreting the rule though… can you use a push-switch (kinda like the offbutton of the power distribution board) and a pull switch? (like a lamp)
http://forums.usfirst.org/showthread.php?t=16347
If it fits that description, it’s good. If not, it’s not.
I’ve never seen a lamp style switch that goes into a switchbox in a wall… If you can find one it’s legal, if not then no.
I’ve also never seen a single push button switch, although rocker style switches would probably work in a similar manner and are available.
