Here is our code that is not working. We don’t understand why it is not working:
package frc.robot;
import edu.wpi.first.wpilibj.Timer;
import com.ctre.phoenix.motorcontrol.*;
import com.ctre.phoenix.motorcontrol.can.*;
import edu.wpi.first.networktables.NetworkTable;
import edu.wpi.first.networktables.NetworkTableEntry;
import edu.wpi.first.networktables.NetworkTableInstance;
// Motor controllers
TalonSRX _talon0 = new TalonSRX(1);
TalonSRX _talon1 = new TalonSRX(3);
TalonSRX _talon2 = new TalonSRX(5);
TalonSRX _talon3 = new TalonSRX(2);
TalonSRX _talon4 = new TalonSRX(4);
TalonSRX _talon5 = new TalonSRX(6);
// Joystick (for teleop)
Joystick _joystick = new Joystick(0);
// Autonomous variables
private Timer autoTimer = new Timer();
private final double AUTO_TIME = 15.0; // Autonomous period in seconds
private final double TARGET_DISTANCE = 5.0; // Target distance in feet
private boolean reachedTarget = false;
// Network Tables for Limelight
NetworkTable limelightTable;
@Override
public void robotInit() {
// Initialize Network Tables
limelightTable = NetworkTableInstance.getDefault().getTable("limelight");
// Robot initialization code here (if any)
@Override
// Reset and start the autonomous timer
autoTimer.reset();
autoTimer.start();
// Initial motor configuration for autonomous
_talon0.setInverted(false);
_talon2.setInverted(false);
_talon4.setInverted(false);
_talon1.setInverted(true);
_talon3.setInverted(true);
_talon5.setInverted(true);
@Override
// Check if the autonomous period is still active and the target hasn't been reached
// if (autoTimer.get() < AUTO_TIME && !reachedTarget) {
// Get Limelight data
NetworkTableEntry tv = limelightTable.getEntry("tv"); // Whether the limelight has any valid targets (0 or 1)
NetworkTableEntry tx = limelightTable.getEntry("tx"); // Horizontal Offset From Crosshair To Target (-27 degrees to 27 degrees)
NetworkTableEntry ty = limelightTable.getEntry("ty"); // Vertical Offset From Crosshair To Target (-20.5 degrees to 20.5 degrees)
double targetVisible = tv.getDouble(0);
double targetX = tx.getDouble(0);Preformatted text
double targetY = ty.getDouble(0);
SmartDashboard.putNumber("TX", targetX);
SmartDashboard.putNumber("TV", targetVisible);
// if (targetVisible) {
double steer = targetX * 0.3;
double drive = -0.02 * targetY;
drive = Math.max(drive, 0.4);
double leftCommand = drive + steer;
double rightCommand = drive - steer;
_talon0.set(ControlMode.PercentOutput, leftCommand);
_talon1.set(ControlMode.PercentOutput, leftCommand);
_talon2.set(ControlMode.PercentOutput, leftCommand);
_talon3.set(ControlMode.PercentOutput, rightCommand);
_talon4.set(ControlMode.PercentOutput, rightCommand);
_talon5.set(ControlMode.PercentOutput, rightCommand);
// } else {
// Stop or search for target
// stopMotors();
// } else {
// Stop the robot
// stopMotors();
void stopMotors() {
_talon0.set(ControlMode.PercentOutput, 0);
_talon1.set(ControlMode.PercentOutput, 0);
_talon2.set(ControlMode.PercentOutput, 0);
_talon3.set(ControlMode.PercentOutput, 0);
_talon4.set(ControlMode.PercentOutput, 0);
_talon5.set(ControlMode.PercentOutput, 0);
@Override
