How do you find the number of april tags detected by limelight?
You must use the JSON output (LimelightHelpers is helpful) and look for the length of the fiducals array result.targets_Fiducials.length
Yes everyone wishes it was easier. I made an issue here.
Thanks, I counted the number of occurrences of “pts” in the JSON dump since “pts” only occurs once per tag.
public int getNumTargets() {
return countStringOccurrences(NetworkTableInstance.getDefault().getTable(m_name).getEntry("json").getString(""), "pts");
private int countStringOccurrences(String str, String substr) {
int occurrences = 0;
for (int i = 0; i < str.length()-substr.length()+1; i++) {
if (str.substring(i, i+substr.length()).equals(substr)) {
occurrences++;
return occurrences;
Now Limelight provides a number for the tag count, it is the 7th index of the botpose array Complete NetworkTables API | Limelight Documentation
