My team is trying to use Limelight 2, but we are struggling with low FPS, do you have any ideas?
Are you using a grip pipeline or the built in limelight pipeline? One thing that can cause low framerate is having multiple streams open at once. Try closing your browser and making sure it doesn’t keep the tabs loaded, and see if that resovles framerate issues.
Think we get 90 fps in testing
We were using both but you are probably right, thanks!
Did you play around with any of the setting, or were you 90 fps out of the box?
Not sure , I will try to find out later
