The docs just say that you should use the Web UI, but I cannot find an “Upload .fmap” link/button. We are running Limelight 3 2023.6.
Can someone ELI5 which tab / page on the Web UI for .fmap upload? Or if there’s an address to POST or whatever?
Once your limelight is powered on and you are connected to it’s web interface, set your pipeline type to April tag, then turn on full 3d tracking in the advanced tab. Once that is enabled, you should see an upload button, circled in the image below
Perfect! Thank you!
Out of curiosity, what fmap file are you uploading? Did you make your own map?
