Limelight keeps crashing
So i am trying to get a limelight 2+ working, and it doesn’t seem to be working. I flashed it with the newest image and connected it to the robot and everything, but when it tries to startup it just flashes 3 times and the lights turn off, then it tries again 10 seconds later over and over again. I connected it to my PC with a 12V passive PoE injector to try to diagnose it, and nothing seems to work. Sometimes it holds the LEDS for about 10 seconds, and then turns off again. I took it apart and there seems to be a red light on the camera board that flashes when it fails, and holds solid when the LEDS stay on for a bit, before crashing again. I believe there may be some hardware issues, but I can’t figure out for sure what the problem is. It shows up briefly on the limelight finder, but when I try to configure it, it doesn’t connect at all. Also, I dont know if this is important but the limelight finder says the netmask is 255.255.0.0 and it is in red
I found the problem, I it needed more power than i was giving it.
