I don’t believe so. I would have to check next week since our school has biweekly meetings for robotics.
If LL is not publishing the data under publishers what steps should I take?
maybe reflash its firmware, or mess with its NT debug/config options. im personally not experienced with LL, so if its true that theres nothing publishing to the topic, then at least you know where the issue is coming from
I’m a bit confused on what changing the laptop’s static IP actually does. From what I’ve seen so far, I can connect to the limelight just fine with default IP? (wireless)
