We saw that theres new releases for the limelight, however after installing all of them we ran into a problem. When opening BalenaEtcher and trying to select a target, both our limelight 2+ and 3 don’t seen to appear in BalenaEtcher. We’re connected to USB and all, but for some reason it just doesn’t appear.
Do you have all the correct drivers? I had the same issue and it was resolved when I downloaded the drivers necessary to write to the Limelight. It should be on the setup page on the documentation.
I recently had this problem, it’s a dumb problem. First, unplug your limelight from everything and then connect to it via USB C cable from your laptop. THEN, once the limelight has booted up (you can tell based one of its lights turning green) you launch Etcher.
