Hey I’ve been trying to get pose estimation with limelight to work, but I’m running into a weird issue. Whenever the robot is turned on my code crashes due to the tagCount method returning null. However, if I redeploy code that issue no longer occurs and localization seems to work as intended. I haven’t seen anyone else with this problem and we obviously won’t be able to redeploy code every time we turn the robot on at events. Any help would be great. My code is based on the megatag examples on the limelight docs.
public Swerve(){
m_poseEstimator = new SwerveDrivePoseEstimator(
Constants.Swerve.swerveKinematics,
gyro.getRotation2d(),
new SwerveModulePosition[] {
mSwerveMods[0].getPosition(),
mSwerveMods[1].getPosition(),
mSwerveMods[2].getPosition(),
mSwerveMods[3].getPosition()
new Pose2d(),
VecBuilder.fill(0.05, 0.05, Units.degreesToRadians(5)),
VecBuilder.fill(0.5, 0.5, Units.degreesToRadians(30)));
public void updatePose(){
m_poseEstimator.update(
if(useMegaTag2 == false)
LimelightHelpers.PoseEstimate mt1 = LimelightHelpers.getBotPoseEstimate_wpiBlue("limelight");
if(mt1.tagCount == 1 && mt1.rawFiducials.length == 1)
if(mt1.rawFiducials[0].ambiguity > .7)
doRejectUpdate = true;
if(mt1.rawFiducials[0].distToCamera > 3)
if(mt1.tagCount == 0)
if(!doRejectUpdate)
m_poseEstimator.setVisionMeasurementStdDevs(VecBuilder.fill(.5,.5,.999999));
m_poseEstimator.addVisionMeasurement(
mt1.pose,
mt1.timestampSeconds);
else if (useMegaTag2 == true)
LimelightHelpers.SetRobotOrientation("limelight", m_poseEstimator.getEstimatedPosition().getRotation().getDegrees(), 0, 0, 0, 0, 0);
LimelightHelpers.PoseEstimate mt2 = LimelightHelpers.getBotPoseEstimate_wpiBlue_MegaTag2("limelight");
if(Math.abs(gyro.getRate()) > 720) // if our angular velocity is greater than 720 degrees per second, ignore vision updates
if(mt2.tagCount == 0)
if(!doRejectUpdate)
m_poseEstimator.setVisionMeasurementStdDevs(VecBuilder.fill(.5,.5,9999999));
mt2.pose,
mt2.timestampSeconds);
The updatePose() method is called periodically.
