Limelight Red and Blue Balance - Why?
What would be the reason to adjust the red and blue balance values.
Documentation says to keep them at the default. What are the default values? I think someone messed with them on our Limelight but I’ve built a pipeline I don’t want to have to recreate.
Subtracting out the Red and Blue channels of the image can help accentuate the greens, but it comes at a cost of a lot of green when you’re just trying to find the target.
I can’t get you our values until tomorrow, but if you need them I’m happy to share.
@Brandon_Hjelstrom We too had a similar thing happen where we accidentally changed the wrong value and had to boot up our other limelight to find the default.
Adding a small “reset to default” button for every slider/value would be very helpful. (Unless this already exists and I’m just blind).
Open a different pipeline. They should be at default.
How?
Select ignore NetworkTables
Select pipeline 1-9
Agreed. I messed a bit with the sliders because i got too excited about getting to the dashboard. Ended up making the feed as close as it can be to what a USB camera sees.
