Limelight tx and tv value not communicating with robot
Below is the code to get the limelight tx value. On the limelight stream, the tx value changes in real-time, but when using Smart Dashboard, the tx value stays on 0, which is the default. Even when changing the default value it doesn’t update with the real time value, only staying at the default and then the robot stops moving.
