We’re trying to program a digital input with a limit switch. How do we set the if statement?
This is what we have so far
if(Clamplimit -> Get() > 0)
s[0] -> Set(false);
s[1] -> Set(true);
Is it correct?
s[0] -> Set(false);
s[1] -> Set(true);
Is it correct?
How you write the if statement depends on what you want it to do.
What do you want it to do?
We have a claw connected to solenoids 7 and 6. We want the limit switch to close the claw when it’s hit
You just need to turn
if (limit_switch_active)
activate_solenoid_6;
activate_solenoid_7;
into real code that compiles.
Replace limit_switch_active with whatever it takes to read your limit switch. That’s something like Clamplimit->Get(), right? Replace the activate_solenoid_# with whatever it takes to put your solenoids in the desired state. I don’t know how you’ve instantiated your limit switch or your solenoids, and I don’t know how they are wired, so I can’t give you working code to copy and paste.
I assume you’ll want some way to open the claw later, right?
This is how we have it set up
DigitalInput *Clamplimit; //Limit Switch for clamp
Clamplimit = new DigitalInput(2); //Limit Switch for clamp (Digital Input)
if(Clamplimit)
s[6] -> Set(false);
s[7] -> Set(true);
Will this work as is?
No, it needs to be:
if(Clamplimit->Get())
s[6] -> Set(false);
s[7] -> Set(true);
Also, what class is s an instance of?
