Linear Actuator Legality
Are these (P16-P Linear Actuator (200mm, 256:1, 12V) | ACT-U8) Linear Actuators legal for this year’s game? We couldn’t find any rules specifically pertaining to linear actuators.
Thanks!
The actuator is legal, but the motor powering it probably is not.
For more details, open your Game Manual to Section 9 and find R501. R501 states that ONLY the motors and actuators in [long list] are legal, but in any quantity. You’ll notice that no linear actuators are listed.
However… the part this controls is the motor, NOT the gearbox, and there’s a pretty convincing argument that most of the actuator is actually a gearbox. So, what you do here is if you want to use the actuator, you open it up, check the motor against the legal list in R501, and if it’s not a legal motor, you replace it with a legal motor of a similar class. (e.g., if it’s a 775-size motor, slap a 775Pro or a Redline in there.) Then you need to be ready to show that yes, there is a legal motor in there, here’s the conversion (inspectors can be a bit picky about that).
Incidentally… see if DART 6 in. Actuator Kit - AndyMark, Inc will help you out.
If you are looking for a low power, short distance linear actuator like what was in the original post, AndyMark sells a few options like these:
These qualify as “servos” so they are legal.
