Linear actuator recommendations
Does anyone have any good recommendations for linear actuators that can extend 18inches in a matter of a second and can hold about 10-20 lbs?
Was literally going to ask the same question! REV makes a good one, but its currently out of stock till supposedly mid-january. Although REV’s isn’t 2 ft extension.
You’re not going to find it COTS–automotive linear actuators are designed for torque rather than speed.
For the load, I’d entertain pneumatics or a COTS elevator kit instead.
At that speed? Pneumatic cylinder, 1/2" bore with a pressure regulator to limit the force should do it.
If you want the calculations let me know.
Fast actuation over long distances is more the province of pneumatics than linear actuators (assuming you only need to move between two positions).
Consider a linear actuator using 1/4-20 threaded rod as the screw. To move it 18", you will need to rotate the screw 18 x 20 times. To do that in one second, you will need to rotate at 18 x 20 x 60 = 21600 rpm.
A NEO 550 has an 11000 rpm no-load speed. A 775 Redline claims to have a 21020 no-load, but of course under any sort of load it’s going to be significantly lower, but you might get up into the 12"/sec range if it’s lightly loaded.
As it happens, I designed a largely 3D-printed linear actuator just to see what could be done cheaply. It gets about 6"/sec with a NEO550 but I also made a variant that accepts a 775 (though I haven’t tested that out).
You can find it (and a lot of other 3D printed FRC mechanisms) here: GitHub - RJWoodhead/FRC3DP
Here’s a clip of the device being powered by a NEO 550 (unloaded): https://www.youtube.com/shorts/NUQg79O8sjk
It’s a quick print and build so you might give it a shot.
Rereading your post, I missed part of your requirements.
You might also look into the StrongArm build in the same repo. That will definitely handle the load and speed, but it’s a bit of a beefy boi.
How about climber on 2020everybot?
If pneumatics are not an option (although I agree with posters above on them being a great option for this use case and probably the cheapest) how about:
