I got a “linking error” when I compiled my code:
“.code_sqrt.o’ can not fit in the section. Section ’ code_sqrt.o’ length=0x00000442”
what does this mean?
It looks like your floating point calculations have completely filled your processors memory.
If you are only using the sqrt function, you might like to see the implementation of InvSqrt():
http://www.beyond3d.com/articles/fastinvsqrt/
here is an implementation that I compiled on my first controller (the scary constant is a standard IEEE754 floating point number, so it will work on every microprocessor the same way).
I would definitely extensively test this method before putting it to use (i.e. don’t hook up motors until you are sure it gives the expected answers), but I believe that it is just a first-order Newton’s method approximation, with the constant being a first guess I believe.
I’m pretty sure it will take up less space than the included math library.
float invSqrt(float magnitudeSquared) {
float xhalf;
float temp;
long i;
// magic follows:
temp = magnitudeSquared;
xhalf = 0.5f*temp;
i = *(long*)&temp;
i = 0x5f3759df - (i>>1);
temp = *(float*)&i;
temp = temp*(1.5f - xhalf*temp*temp);
// temp now contains the 1/sqrt(magnitudeSquared)
return temp;
Definitely works on the computer:
5629.000: InvSqrt 0.013318; 1/sqrt 0.013329
281.0000: InvSqrt 0.059639; 1/sqrt 0.059655
28.00000: InvSqrt 0.188722; 1/sqrt 0.188982
6.000000: InvSqrt 0.407681; 1/sqrt 0.408248
4.000000: InvSqrt 0.499154; 1/sqrt 0.500000
2.017857: InvSqrt 0.703756; 1/sqrt 0.703971
0.250000: InvSqrt 1.996614; 1/sqrt 2.000000
0.166667: InvSqrt 2.445322; 1/sqrt 2.449490
0.000000: InvSqrt 19817753709685768192; 1/sqrt inf
