LINKING ERRORS!!!
Hey guys, when we compile our code in EasyC, we get a linking error and the error says: Error- section ‘.code_u2open.o’ can not fit the section. Section ‘.code_u2open.o’ length=0x00000064. We’re dividing with floats and that seems to be the problem because it works with ints. Any ideas???
You’ve run out of Program Memory on the controller.
If you need those decimals, you could just scale them up by a few factors of ten so you can use ints, divide, then scale it back down.
It’ll be faster too.
Scale up by factors of 2. Then you can use << instead of *. It’s a heck of a lot quicker. You still have to divide unless you’re using unsigned ints, however.
Alright thanks guys, helped a lot and we’re back on track now!!!
