will linux do it because i am gettin linux an drunning it on a cheesey 10 gig harddrive and am wonderig if it will program
Could you define “do it”? As long as you get WINE, you should be set if I’m not mistaken, but it will require some effort on your part to get most things functioning properly.
Search please.
Yep, you can definitely get Linux working with the robot controller. I did all of last year and it worked out perfectly.
Some helpful links to, well, help you get started:
- Install MCC18 in the proper place.
- Use Eclipse as your IDE – I actually didn’t do this. Instead, I used a Makefile
- For getting the programs onto the robot controller, nothing beats the IFILoader Reloaded
sorry for a clarification on the “do it” I meen for IFI robotics for first i jus tneed to install the stuff needed fot it. I am new to getting linux so I am gaining knowledge as I go I have yet to install it I’m just getting info on it.
