LiveVision broken with Java
Just checking out new tools. Load Java robot project into roboRio; when we throw it into test mode, the Java SmartDashbaord just goes blank.
We’ve scratched the old save.xml for SmartDashaboard; that didn’t help.
Having the same problem with 2 different PCs.
Has anyone else seen this?
I assume you mean LiveWindow?
It works with our 2015 robot code ported to 2016. If you run Smartdashboard from the command line, is there anything printed when you switch to test mode?
Also, there was an update yesterday that fixed a few crashing issues in SmartDashboard. Can you ensure that your tools are updated? (Eclipse -> Help -> Check For Updates)
