Load rating VP Universal Female Output Shaft
Anyone know where to find the load ratings guide info for VP used w/ Universal Female Output Shaft (to 1/2 hex). The guide posted here does not appear to have been updated with this info.
Is it safe to assume it’s similar to the 1/2 hex output load ratings?
In any case, I would not use this end without a bearing at the other end of the shaft. It has a fair amount of play in it. Unless we hear something from Vex, I would play this conservatively and use the CIM output shaft values.
Agreed that having a support bearing on end of the shaft is a requirement.
