Loading bay ball output question
Does anyone know whether the human Player can affect how the fuel cell comes out of the loading chute?
My team is debating how much faster you can load from the upper chutes and whether its worth it to have some sort of top acquiring solution. If you can jam 5 down the lower chute just as fast, your ground acquisition can grab them and you dont have to worry about it.
The reason this came up is in the field tour video: https://youtu.be/41UgChIeSQw , the lower chute takes a lot longer for the ball to come out than the upper chute but they have almost identical CAD drawings.
If anyone has access to a realistic loading bay, I’d greatly appreciate some clarification on whether this is always a problem!
I believe it was stated in the initial broadcast stream that they should drop at the same time and any force imparted by the human player is negligible.
Could you do a timestamp perhaps? I just know that in the video I linked, they came out differently…
I don’t have a timestamp but its when Kamen first started introducing the field.
