Where trying to make a custom shuffleboard layout for our robot this year but some of the functionality we what to access(boolean colors, widget sizing) can’t be done via code so we are wanting to just load a pre-made json layout. is there a way we can load the layout from code rather then having to do it manually every time?
If you plan on using the same computer you did your programming on to also run driverstation at your events, you can save a shuffleboard layout separate from your programming and have it load as default in the program.
Similarly to how you would say open a document in Microsoft Word, file → open layout
