I’m looking for some very large flanged ball bearings with an inner diameter/ bore diameter of 1.125 inches and I can’t seem to find it only. Please help…
-Johnson
While Andrew’s is the only flanged one on McM, you have other (and better) options than a $55 bearing. Firstly, you could use one of the other 1.125" ID ball bearings and either press-fit them into a bore or hold them in place with a few button-head screws.
Alternately, if you are under a low-RPM use constraint, consider using bushings instead. They tend to have higher load ratings in exchange for lower speed ratings. McMaster-Carr offers plenty, both flanged and non-flanged. The nice part is that if one isn’t quite the right size, it’s pretty straightforward to turn it down to size.
Not really sure exactly what you are thinking of using this bearing for, but a quick google search turned up lots of options.
I have not purchased anything from this source, ever, so this is not an endorsement, but this bearing is reasonably priced and meets your criteria of 1-1/8" bore: https://www.thebigbearingstore.com/r18-2rs-r18-zz-radial-ball-bearing-1-1-8-bore/
Also, you may want to look at [oil impregnated] bronze bushings, especially if your speeds aren’t really high. If you go this route, I recommend polishing the shaft in the area where it goes through the bushing with some very fine sandpaper or similar.
Our teams has a positive experience with https://www.igus.com bushings as a lighter and possibly cheaper alternative to bronze as well.
I saw a few people recommend McMaster, which I’d definitely do. If not, Grainger might have a couple that’ll work.
I’m sure it’s not as helpful today (end of build) but the best value in large bearings is ebay. The problem is, it takes a month to get the parts from China. Also, going to mm bearings instead of inch-bearings saves a great deal of money.
Last year we designed a module where we placed bearings around mini-cim motors that were actually mounted inside the wheels…it was tempting to use 2.5 inch bearings, but going to 65 mm at $6.33 each made the price bear-able (dad-pun).
Try this link if you’re curious…but yes, it takes a month or more to get the parts.
