We have an issue in our code starting with the new season ever since we updated our CTRE Phoenix framework. We have written code for our robot after updating everything (radio, RoboRio, wpilib vscode, etc.) and after deploying we get this error: Warning at edu.wpi.first.wpilibj.IterativeRobotBase.printLoopOverrunMessage(IterativeRobotBase.java:276): Loop time of 0.02s overrun
For reference, we are coding in Java.
We have tried adding leftVictor.setExpiration(5.0); rightVictor.setExpiration(5.0);
to robotInit() in our code, but we receive the same exact error, 0.2 seconds included (doesn’t change loop time)
Do you just get that message once on startup? Because of how Java works, that message has about a 90% chance of occuring the first iteration of robot code, and safely can be ignored. You only need to be concerned if it happens continuously and often.
It does only occur once on startup, but our code won’t run and we think this is the cause. It additionally occurs every time code is deployed without failure (so far)
There is something else causing your code to not run. That message in itself will not cause code to not run, and because of how Java works it will happen every time code deploys or restarts. That message can safely be ignored on startup, and will not cause code to not work. Is there any other messages occurring?
Also, does your code seem to be continously rebooting? If not, you might have an infinite loop somewhere in your robot code. We’d need to see your code or another error message to help debug that.
What makes you think your code isn’t running? I don’t see any print statements or other diagnostics in there; it seems entirely likely that it’s running just fine and simply isn’t doing what you expect it to.
