Lost 987 Jacket
Hello,
At the Houston Championship there was a 987 black hoodie jacket left on top of a table against the wall in the Hall of Fame are where 987 raised the banner (front lobby of the convention center). Inside one of the jacket pockets was a set of keys that were on a black WPI lanyard. The other pocket, some pens.
I’ve checked with the team, and will be checking with FIRST lost and found first thing in the morning. However, if it does not show up from either sources, if anyone has seen or know its whereabouts, PLEASE return in. In particular, the keys that reside in them. Thank you.
Bump, unless you found your stuff in which case pm me and I’ll delete this post
Alas I have not, as would have updated. Thank you though. I check security and lost and found and alas nothing :frowning: Gave them my info and what is missing so if they do recieve anything, they should be contacting me. At this point I just want the keys back if anything.
Nostalgia
:slight_smile:
I thought I was having some major deja vu, sad this happened again. Hopefully someone finds the jacket like last time.
Bump, as we near the end of the Houston championship.
