Lumen output of green led light ring in FIRST Choice
With vision targeting requiring a bright source of light does anybody know the lumen output of the light ring available in FIRST Choice? Also how effective is the light ring at longer distances? Thanks
The lumen output is right on the First Choice page: http://firstchoicebyandymark.com/en/fc14-060
The distance will depend heavily on your vision code and camera settings. If you’re code can reject false detections, you can open up the thresholds and your light doesn’t need to be as bright. Alternately, if you turn down the brightness of the camera, you will need a brighter light, but it will minimize the number of false detections. The best thing to do is start playing with it now.
In 2012, we used only 6 LEDs (significantly less bright then the FC ring light). We could detect the vision targets from the key (12 feet away).
Thanks for the quick reply. Overlooked that information :stuck_out_tongue: will be of great help. Thanks
