Does anyone have an example of using the Mach Engineering Touchless encoder with LabView?
Thanks. in advance
Thanks. in advance
In the Installed Examples under Resources on the getting started window look under Digital for UpDown Counter.
That example, without the optional “Counter Down Channel” input is what you need to be doing to use that encoder.
Many thanks Trying it today.
Hi - Our Team is trying to use the AM-3507 Touchless Encoders, but with Java. We have them plugged into the DIO ports, and trying to use the sample code, but are not reading anything from the encoders.
Has anyone else tried to use these in Java? Should we be using the analog input instead of the DIO? Any suggestions would be appreciated!
