We’re getting the lab cleaned up for this coming season which means it’s time to clean our CNC mill’s coolant system. It’s a Tormach 1100 by the way. This is always a huge mess which brings me to the question.
How bad would it be to mill aluminum without coolant?
We currently just use a constant compressed air stream to keep the chips at bay on our CNC router. Could we do the same with the mill? That way we could just vac them up. Sure the bits won’t last AS long but how big a difference are we talking?
We never machine steel on the mill, it’s alway aluminum.
Also, how about the cold saw? Is coolant really important there?
Compressed air is the way to go. You can use mist coolant with a simple tank and an air line, but even compressed air alone is quite powerful. We currently run flood coolant but will be upgrading to mist based on our experiences with the droopy Tormach coolant pump.
I can’t speak to cutting metal on a cold saw.
EDIT: 115 runs without coolant, just a vacuum. I like spraying some lubricant on there to prevent galling and chips welding to the sides of the cut. A 4mm endmill at 43ipm in aluminum does well when slotting with a 1/16" stepdown. More aggressive stepdowns in thin material (like 1/16" or 1/8") can actually help reduce galling and chips welding to the work.
Actually - it’s pretty cool that you’re asking this question. Over the last 5 years my workplace has been moving to a coolant-free machining system for mass production.
It is a little more expensive in terms of tooling and you can’t hit the bits quite as hard, but the benefits of being able to recycle the aluminum without them being a waste that needs to be cleaned first is a cost savings on the flip side.
So you’re saving yourself the hassle, and being green.
Good point. I was just thinking of the hassle of cleaning out the coolant and then dealing with that toxic waste. Being able to recycle the chips is great.
Anyone have experience with using a cold saw on aluminum without coolant?
My experience is that milling/turning Al with constant air is ok as long as you have your feed/speed, DOC dialed in. However, coolant will give you a much larger margin of error. Be sure your air source doesn’t move away from the tool. Again, you have less margin and you can’t afford to lose the air flow.
When you get the parameters too far off, you’ll generate too much heat into the part which will affect your tolerances (thermal expansion). You’ll start to gall and clog the flutes. That will exacerbate the problem and then break the cutter and possibly trash the part. Your surface finish will probably not be acceptable.
Remember, the chips will carry away most of the heat from the cutting/shearing/friction of the cutter against the stock. Getting rid of the chips (evacuation) is most important. You can do this, as you state, with compressed air, flood, or mist.
I think most of the problems mentioned above are of less importance to a FIRST bot, but I would hesitate to give those parts to a buyer who is paying $$.
re: Cold saw.
As mentioned, you could do it when your speed/feed is correct. However, in saws I’m familiar with, your speed is already determined and you can’t really control your feed rate (other than visually and audibly). Coolant creates a giant mess, so we use stick wax liberally applied.
I’ll add on to the coolant-free club here. We use our CNC mill without any coolant, just compressed air and a bit of cutting fluid on the part. It’s an educational machine so it’s relatively slow (40 ipm, 2mm DoC, 5mm endmill IIRC) but it works well for us. The cuts are all within a decent tolerance, and we haven’t noticed significant wear on the endmills despite getting a good amount of use. This is true for 6061, 7075, and a bit of 6063 (ugh).
As far as the cold saw, I’ve never used coolant with a saw on aluminum. A miter saw with a non-ferrous metal blade will do pretty much everything you need. You can use a bit of cutting fluid or blade wax but it isn’t really needed. With the tolerances we expect a saw to hold for an FRC application, thermal expansion isn’t a big factor.
Edit: To be clear, I’m not recommending running the cold saw without coolant. I just think a cold saw is overkill for FRC and a miter saw makes a lot less mess.
It really depends on what kind of cut you are making. If you are just face/side milling stock down to size, it will be more than okay to use no coolant whatsoever or just mist coolant. If you are making deeper cuts (for aluminum I’d say anything over 0.5”) into the material, it would definitely be wise to use flood coolant to avoid chip buildup on the tool or on the part, as this can ruin your endmills very fast. I personally have ruined a brand new carbide endmill by milling a slot in material without using coolant.
When we got our CNC router it came with a Unist mister. It basically sprays a fine mist of light oil. A small cup sized reservoir lasts all year. I was so impressed with how well it worked, I put misters on nearly all of our machines (mill, lathe, chop saw). They aren’t cheap, but they are so much cleaner than coolant. We tried a conventional coolant setup on our CNC mill, but in a school where machines sit idle for long periods of time, the coolant was always evaporating and getting fouled. Admittedly for heavier machining the mister doesn’t clear chips as well as flood coolant, but the reduced mess makes it so much better.
I would love to cut aluminum dry, but in my experience dry cutting has always been a gamble. Sometimes it works fine, but things go wrong very quickly when chips start to stick to the tool.
I would keep the coolant on the cold saw, those blades are not cheap! The cold saw blades are HSS typically, and have a coating to prevent galling as they pass through the metal. Without cooling you would destroy this coating quickly.
We run very high tooth counts blades for aluminum, 250-280 alternating, 3mm width. One of my favorite tools, very accurate, straight, & clean cuts on any aluminum shaft or section.
I run an 1100 in my shop without flood coolant (the stock pump seized up years ago from lack of use). I have a koolmist style mister setup that I’ll use for harder materials, like stainless and titanium, but I generally don’t bother with it for aluminum or mild steel unless I’m really trying to nail a finish or I’m new to the tool/material/program. Nine out of ten times I pull the pickup tube out of the coolant and use it as an airblast.
The 1100 is a low enough power machine, and modern CAM is so good, that it’s hard to overheat even HSS tools or the part when cutting aluminum at proper feed rates. So the problem you’re left with is evacuating chips to avoid recutting, something an airblast generally does just fine.
Ran a Haas machine the whole summer with a super spotty mister. Eventually dumped the kool-mist out and used it just to blast compressed air. Worked great in stainless and aluminum. Used cutting oil manually applied with a acid brush to improve finish when needed. Probably not as great for tool life as the flood coolant we run at school but worked super well to evacuate chips. You definitely gotta be careful running drill bits though or they can seize.
