Made in America
One of the biggest lessons I wish i had learned in high school is how to work with foreign vendors. As I am now working for one of the largest toy producers in the US I working with China, India, and Ireland on a daily bases.
The learning curve is steep. The language divide is wide.
Take every opportunity you have to learn something more.
One could also make the case that we as FIRST teams are exploiting the environment and ruining it for future generations. After all, we are using mined materials, fossil fuel products, and a good deal of energy (especially considering the number of overnight orders we place). Some teams are even sponsored by oil and gas companies! Lacking any specific data about FIRST competitions and teams as polluters, I’ll go ahead and make the broad assertion that we are having a substantial negative impact. What should we do? Petition FIRST to require that teams only use certified recycled materials? Eliminate plastics such as polycarbonate from FIRST robots? Boycott competitions that don’t show a measured reduction in energy usage? Quit?
Like everything else we do, participating in FIRST makes us part of a much larger system that has both negative and positive impacts over a broad range. Neither the “made in America” issue nor the hypothetical “polluter” issue is simple; both are real, but are so complex that the proposed solution (making it a requirement that FIRST use only “made in America” parts, in this case) would do nothing more than serve as a political gesture that would alienate some, and entirely fail to solve the problem, while making the FIRST experience significantly poorer overall.
I am glad this was pointed out.
As far as the pollution is concerned - that point you make here has crossed my mind several times.
The question we should ask ourselves in response:
was generating these waste products going to produce something worth doing it?
I’d like to say as an engineer that engineering should not just be about meeting deadlines and making what you were asked.
It should also carry with it the responsibility to identify the risk/benefits of what you are doing.
For the waste produced by FIRST operations we produce engineers and people that are sensitive to the engineering mindset.
That fosters a ‘can do’ attitude where people are motivated to explore the possibilities that might otherwise have been denied.
One of those people might someday manage to make sustained nuclear fusion work. How much pollution would that save?
On the topic of economics:
As others have said technology comes and goes.
Economic forces dictate some of the forces.
The willingness of those who engineer in our society to work for less dictates more forces.
When I helped propose building a 2015 FRC control system I proposed building it in America and specifically with vendors of capacity in NJ.
Why? The deadlines were short and I couldn’t afford miscommunications.
I couldn’t afford quality control issues and I can walk into those vendors and look for problems but it would cost big money to walk into my Korean vendors and look around (I’ve done it before).
So on it’s face I disagree that my motivation to make it my backyard was politically motivated.
It was practically motivated.
We could have solved the local tariff issues by local distribution points just like any other large corporation pulls off.
Perhaps. But do you object in principle to the existence of foreign industry? Or just to the existence of international trade?
Specifically, what criteria do you feel should be met for nations to trade amongst each other, instead of trading within themselves?
Why presume that those jobs were in America to begin with, and have now flowed out? It’s not as if there was a time when American-made parts were the only ones on the market.
This is a fair question; so let’s discuss how we might go about answering it.
To start that process, a few clarifications would be beneficial. Could you be a bit more specific about the meaning of “long term”? (10 years? Within our lifetimes? Centuries?) Also, when you say “best”, for what constituency are you optimizing? (America? Human civilization? Earth?) It’s not wrong to propose different policies for different periods and constituencies—but if that’s the case, go ahead and present the framework to support that proposal.
COTS has it’s problems which are often overlooked.
The United States Military is starting to discover that COTS isn’t always the best idea. Sure you save money on the R&D and in the near term you offload the cost of production however in the longer term the price of that savings might be too high.
When a system that depends on COTS outlives the expected and projected lifetime it’s entirely possible that the vendor(s) that provide the COTS parts will cease to be able to provide support when these systems lifetimes are extended to save money. When you are talking about systems of such enormous costs such as military systems it’s possible to find yourself having to engineer parts anyway with experience that was never internal because of COTS.
So I would argue that using COTS parts engineered without full disclosure required in any system runs risks. Move the production source for the COTS part into a place where the language and style is foreign to you and that problem is magnified.
This problem exists beyond hardware. I routinely work on enormously expensive software systems that people bought and that are closed source. If you sit down and review the application of that software you’ll realize you could: make it faster, make it easier, make it more reliable but you can’t because no one wants to own the effort or invest beyond consumerism.
It’s the same problem really. The idea you can shortcut the perspiration that leads to innovation taken a bit too far and no one wanting to accept that reality.
Also I’d like to indirectly respond to the question of foreign trade above. The issue with foreign trade is that foreign trade should not be mistaken to obey uniform commercial code or any sort of expectation of conduct. Literally many foreign ‘companies’ are extensions of the military industrial complexes that rule over their respective countries of origin. So in effect if these foreign ‘companies’ decide to rip you off realize that it is entirely possible to find yourself with no recourse (no one is going to bring military action over a box of junk). The exception to this rule is straight out capitalistic competition. For example: let’s take DC/DC converters sold by several sources from all over the world. In the absence of contracts you can buy from any place at any time. So if these people want to rely on your business they best produce something adequate in that case because at any time you can walk away. Course that works fantastic till you allow monopolies on resources required to make a product at all. Of course the price to you as a product designer using COTS DC/DC converters ‘protected’ by capitalistic competition is that you have to design your product to accept DC/DC converters in various shapes and sizes and maybe with slightly different inputs and outputs and you have to have just enough reserve stock to buffer bad lots and additional delays (it’s a balancing act). So in the end my perspective on this is not that ‘Made in America’ is always better. It’s that my expectations of my country and the society within it are based on a lifetime of experience in my country. There are some things we don’t do well here in America at any one time. If a foreign source can demonstrate to me consistent improvement over my local sources then I balance the risk/benefit equation in their favor because the show must go on.
The real risk is that everyone is too willing to think they can just buy innovation. Real innovation transcends the immediate transaction of funds and goods and leaves lasting positive impact on society. FIRST is real innovation. Look beyond the immediate product, the flow of funds and look at the long term impact. You can build a competitive FIRST robot with some cheap common tools or you can build a FIRST robot with a million dollar shop. It’s not just about the money and the jobs.
Personally, I think that Supplier Selection would make a great discussion topic for a FIRST team. Catch phrases like Make in … can be dissected, better defined, and evaluated against other criteria such as economy, ecology, sustainability, reliability, etc. http://en.wikipedia.org/wiki/Made_in_USA gives background to what the phrase means.
Making students aware of the complexities and how to research to get beyond the catch-phrases, will allow them to make informed choices on their robot, team tshirts, website hosting, etc. It can also be helpful in their daily actions outside of FIRST.
A first step might be to research some of the elements in the KOP. Basic NI information is available on ni.com/company, and additional details of our own supplier selection criteria is available from there. Annual reports such as http://biz.yahoo.com/e/140220/nati10-k.html will provide additional material.
I’d be curious to hear about the outcome of such a discussion.
Greg McKaskle
Nationalism is dumb, it’s saying I’m better than you because of where I or my parents were born.
Counterpoint to ‘money flowing overseas’ is Walmart. They have huge revenues, but suck money out of communities to do so, sending it to shareholders and the Waltons, 6 of whom have the same wealth (~$90B0 as the bottom 42% of this country. The money is staying in this country, but you don’t see that in the salaries or benefits of the people that work for Walmart.
Nationalism might be dumb - but competing for the best of something is not by necessity nationalism.
The problem with nationalism is that there’s often no actual measurement involved - just bias.
It would be difficult to prove that the Walmart wealth is entirely within America even if the owners of that wealth are in America. With our complicated tax codes there’s every reason to believe that Walmart has accountants smart enough to offshore considerable amounts of money that they don’t need to pay for their workforce or operations in America. Hence the value in not adding to the cost of the workforce or operations in America that’s money they have to keep here.
It’s like CEOs that make $1. They don’t really make $1 in the real world. That’s just their salary and they live off the capital gains which are taxed differently. That’s how Warren Buffet often pays less tax than his employees.
I work on Wall Street. Money generally attracts money. Money gives a single person a voice that drowns out thousands of other voices. Money can allow people to get away with things that the rest of us would rot in jail for. Money in the hands of dictators and other violent people can buy weapons that can do enormous harm. Don’t blame the tool look at the intentions of the people wielding it.
This post deserved more attention.
I agree that America can’t compete with Chinese prices, but there are other factors that come to play when deciding on where to buy from. Comparative advantage is a powerful thing. We can’t shy away from these questions, and i’m glad this discussion is being handled in a rational and respectful manor.
By the way, take it from someone who’s at his first internship in the CIS field: The jobs are still out there, but it’s not a guarantee that you can get one straight out of college if you don’t go the extra mile. There’s tough competition out there, so students will simply have to rise to meet the challenge. America needs to step it’s game up, and we are doing just that with this program. Imposing artificial limits within the program is the WRONG way to inspire students.
From what I’ve noticed, things made in America don’t tend to be of the greatest quality. Sure some stuff may be good, but for the most part it tends to cost more and is of lower quality than imported goods.
Like the output of any group of people sometimes there are problems.
I’ve had good luck with some stuff made in America.
Especially when I am making it America :]
We have been saying this year that our robot is “Made in China” and “Assembled in America”. We certainly kept the VexPro employees employed this year as our robot BOM has a large amount of VexPro product on it…
We have said before that would could not buy the gears we used to build our own ball shifting transmissions for the price of a complete VexPro one.
We have certainly ran in to some quality issues over the past two years with the VexPro product, but the large majority of it has been excellent. Especially the Ball Shifters. :smiley:
It was very obvious this year that VexPro is providing the product that teams need even though the majority of it is made in China.
For various reasons, most of the respondents of this poll agree with each other that we should continue buying large amounts of imported parts to teach robotics to future engineers. Most CEOs would agree with you, buying imported parts is generally faster and cheaper than purchasing more expensive components manufactured at America’s higher wages.
CEOs can get more product out the door and thus more profit using imported parts, just like we can get more robot into the bag mirroring that same corporate approach, the same approach that outsources technology jobs. Like a flu vaccine, is the cure also a modified version of the disease? This is certainly interesting to say the least.
You are still implying that buying parts manufactured overseas necessarily sends technology jobs away. It does not. There will always be a need for smart people to perform technology jobs everywhere. When they are performing tasks that are better suited to being done by robots or cheaper labour via outsourcing, their talent is being wasted. They could instead be advancing the technology, developing new solutions.
You seem to have a very “Detroit Three” view of how manufacturing should be done. The Japanese car manufacturers have been producing cars of similar quality to the Detroit Three for many years. By doing so more efficiently, utilizing technology to replace menial labour, and outsourcing the production of parts where it is efficient to do so, the Japanese manufacturers are consistently able to sell their cars cheaper than the Detroit Three. It is only recently that they’re starting to adopt similar manufacturing models.
We have the technology today to manufacture automobiles in an almost entirely automated fashion using robots. The talents of the people assembling them in factories around the world are largely being wasted in the name of protecting their jobs.
I can only imagine the progress humanity could make if those people were being utilized to their fullest potential.
While the OP certainly hasn’t provided evidence to support his assertion, neither have those who claim he’s incorrect, beyond a single anecdote anyway. How about, rather than saying “no, you’re wrong,” someone on either side of this debate actually supports their opininos with evidence?
Well,
This article shows US unemployment rate for IT workers is significantly below the overall average: http://www.computerworld.com/s/article/9235797/Dice_US_tech_unemployment_stands_at_3.3_
This article shows a similar result for Canada: http://www.procom.ca/news/canadian-it-sector-has-unique-problem-low-unemployment-rate/
Those together would suggest to me that an ever-increasing outsourcing rate does not yield a loss of tech jobs in North America.
FIRST is no longer US FIRST, the last time they used the US FIRST moniker(wording) was the 1996 season. They haven’t to my knowledge used US FIRST anywhere but the website since then
Oh really?
Also, the shipping label on my mentor pin that arrived in the mail yesterday lists the return address as “US Foundation For Inspiration and Recognition of Science and Technology”.
The 501©(3) is the “United States Foundation For Inspiration and Recognition of Science and Technology”. Has been since it was founded. They’ve been doing business as FIRST® for many years, though.
Just take a look at my earlier post. While FIRST tries there hardest to use just FIRST as much as possible, they are still legally US FIRST and occasionally have to use that name when required.
