our main regulator shows zero psi…
the output arrow is leading to the festo>actuator.
it looks like this.aerial view
top
left right
bottom
the right is the output arrow. leading to actuator
the left is input from the cylinders
the top
is plugged
the bottom has the presssure gauge.
what is wrong here?
Maybe you have the regulator dialed down to 0? Or the Gauge could be broken, I’ve seen broken gauges before too.
The pressure regulator needs to be “dialled in” to the correct pressure.
The top of the regulator forms the cap, which needs to be lifted in order to turn (kind of like a child-proof bottle) then when you push it back down it locks in place.
Jason
