Make two motors speed inverted in SpeedControllerGroup
Hi i want to use two motors but I need one of them to be in an equal speed but inverted , how do I use this with SpeedControllerGroup?
If you are using the DifferentialDrive class from WPILib, it has a right side inverted boolean that it uses. Set it to true.
You should be able to call setInverted on an individual speed controller even if it is in a group.
