Give this a try for making your makefile
#!/usr/bin/env python
#Auto Makefile Generator
#Copyright under terms of GPL
#Based on Team 245's old Makefile....
# Copyright (C) 2005 Team 245
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software Foundation,
# Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
import os
DEBUG=False
VERSION="0.1.92 (0.2 beta 3)"
def printGPLBanner():
print "Makefile Generator, version "+VERSION+", Copyright (C) 2005 Adam-Bots"
print "This software comes with ABSOLUTELY NO WARRANTY"
print "This is free software, and you are welcome to redistribute it under certain conditions; See the accompanying license for details"
def isCygwin():
import os;
return os.platform=='cygwin'
def isLinux():
import os;
return os.platform.beginswith('linux')
def mccPath():
#Find path to the MCC folder.
if isCygwin():
pass
def sprint(msg,level=0):
# Prints a message of a given verbosity:
#Level 0 : Print regardless of status
#Level 1 : Print if DEBUG is set
if level == 0:
print msg
elif level == 1:
if DEBUG:
print "DEBUG:",msg
else:
print msg
def mccCommand():
return "mcc18"
def mccArgs():
return "-D_FRC_BOARD -w3 pa=3 -O+ -nw=2066"
def linkerCommand():
return "mplink"
def mp2hexCommand():
return "mp2hex"
def ifiLoaderCommand():
return "picloader_textmode"
def ifiSerialDevice():
return "/dev/ttyS0"
def ifiReadLogfile():
return "./read.log"
def codePath():
unixish_path="Z:"+os.getcwd()+"//"
return unixish_path.replace("/","\\")
def libPath():
return "/opt/mcc18/lib"
def includePath():
return "/opt/mcc18/h"
def includePathWindows():
return "Z:\\\\opt\\\\mcc18\\\\h"
printGPLBanner();
print
print
print
sprint("Opening the Makefile",1)
print
outfile=open('Makefile','w')
outfile.write('#This is automatically generated by the configure.py script
#Keep your dirty hands off');
outfile.write("
outfile.write('#Run ./configure.py to generate a fresh one.')
outfile.write("
outfile.write('MCC18='+mccCommand())
outfile.write("
outfile.write("PIC=18F8722 # Don't change")
outfile.write("
outfile.write("ARGS="+mccArgs())
outfile.write("
outfile.write("LINKER="+linkerCommand())
outfile.write("
outfile.write("MP2HEX="+mp2hexCommand())
outfile.write("
outfile.write("IFILOAD="+ifiLoaderCommand())
outfile.write("
outfile.write("SERIAL_DEV="+ifiSerialDevice())
outfile.write("
outfile.write("READLOG="+ifiReadLogfile())
outfile.write("
outfile.write("LIB_PATH="+libPath())
outfile.write("
outfile.write("CODE_PATH="+codePath())
outfile.write("
outfile.write("INCLUDE_PATH="+includePath())
outfile.write("
outfile.write("INCLUDE_PATHW="+includePathWindows())
outfile.write("
outfile.write("
sprint("Enumerating Target Object Files...")
import os;
all_targets=""
pipe=os.popen("find . -maxdepth 1 -name \"*.c\" | gawk '{gsub(/\\.c/,\".o\");print}' | uniq",'rt')
line=pipe.readline()
while line != "":
all_targets+=line[2:-1]
all_targets+=" "
all_targets.rstrip()
outfile.write("ALL_TARGETS="+all_targets);
outfile.write("
sprint("Enumerating Header Files...")
pipe=os.popen("find . -name \"*.h\"",'rt')
headers=""
while line != "":
headers+=line[2:-1]
headers+=" "
headers.rstrip()
outfile.write("INCLUDE_FILES="+headers);
outfile.write("
outfile.write("############ Targets: ")
outfile.write("
outfile.write("default: FrcCode.hex")
outfile.write("
sprint("Writing static targets...")
outfile.write("""
#Remove all the individual file backup (The files ending with ~)
#NOTE that this does NOT remove your tbz2 backups!
clean-backup-files:
@echo -e "Removing all the ~ backup files your annoying editor makes..."
@find . -name "*~" |xargs rm -f
#Removes all compiled files from the directory
clean: clean-backup-files clean-deps nohex
@echo -e "Cleaning compiler intermediate files..."
@rm -rf *.o *.err
#Remove deps folder
clean-deps:
@echo -e "Cleaning dependency folder..."
@rm -rf .deps
@mkdir .deps
@touch .deps/dummy
#Remove hexfiles
nohex:
@echo -e "Cleaning linker output and hex files..."
@rm -rf *.hex *.cod *.cof
#These all start the IFI Loader.
safeload: prettycode clean check load
load: FrcCode.hex
$(IFILOAD) FrcCode.hex $(SERIAL_DEV)
read:
@echo -e "Monitoring $(SERIAL_DEV) for data"
@echo -e "Output will also be logged to $(READLOG)"
@echo -e "---------"
@cat $(SERIAL_DEV) | tee $(READLOG) || /bin/true
prettycode:
@echo -e "Using indent to autoformat your .c and .h files..."
@indent *.c *.h
all: clean FrcCode.hex
%.o: %.c
@echo -e "Compiling $@..."
@echo -e "1. Checking Dependencies for $@"
@cpp -nostdinc -isystem $(INCLUDE_PATH) -M -MP $< -MF .deps/$*.deps
@echo -e "2. Launching Compiler..."
@echo -n "A thought to keep you occupied: "
@fortune -s || echo "GET FORTUNE"
@$(MCC18) -p=$(PIC) -fo $@ $< /i\\""$(INCLUDE_PATHW)"\\" $(ARGS)
@echo -e "Done with $@."
FrcCode.hex : $(ALL_TARGETS) $(INCLUDE_FILES)
@echo -e "Linking..."
$(LINKER) /l\\""$(LIB_PATH)"\\" \\""18f8722.lkr"\\" $(ALL_TARGETS) \\""$(CODE_PATH)FRC_library.lib"\\" /m\\""FrcCode.map"\\" /o\\""FrcCode.cof"\\"
$(MP2HEX) FrcCode.cof
.deps/*:
@echo -e "Creating Dependency Makefiles..."
@mkdir -p .deps
@touch .deps/dummy
@echo -e "Done!"
include .deps/*
print
print
sprint("Makefile is generated, setting up working directory....")
os.system('rm -rf .deps')
os.system('mkdir .deps')
os.system('touch .deps/dummy')
print
print
print
sprint("Finished. To build, run 'make'")
