Is there any decent way to this without a lathe? Want to make a hole that I can tap so I can use a bolt and washer to retain stuff but I don’t have any thunderhex.
If it’s just for retention eye-ball it (or scribe in 1/4in from two sides of the hex) and call it a day.
If it needs to be any sort of concentric you can make a jig on a drill press. Thru-drill a block with the tap drill size you want, half-drill with a 37/64ths bit (fits a 1/2in hex shaft just barely), and now you have a guide that will center the tap drill on the end of a hex shaft.
Before thunderhex, and before we had a lathe, we did what James said. Just clamp the shaft vertically in a drill press and eyeball it. If it is just for a retaining bold and washer it does not need to be centered… straight would be best though.
Another trick to find the center of the shaft is to mount it in a bearing and spin it, then apply some moderately coarse sandpaper to the end. Where the circles get down to a point, there you center punch and drill. If the shaft is short enough, you can do the sandpaper part on a drill press.
You can even take this farther:
If it’s not under a heavy load you could try using some churro tube instead of a regular hex axle.
If this is 1/2in hex you are talking about then you could always cut a small (think 1in long) piece of churro and clamp it end on end on top of your 1/2in hex in the vice. The hole in the churro would serve as a guide for your drill bit going into the end of the hex shaft perfectly centered.
We did this in a pinch once because the mill/lathe we have was broken at the time, and it worked great.
Seems like if you’re doing that it’d be a fine use of a transfer punch.
Tweaking @tomithy’s, just use a 1/2" deep socket to keep the churro in place and drill through the driver hole.
I highly highly recommend that until you can buy a lathe your team buy some of these Center Finder / Punch https://www.amazon.com/dp/B07DGJLWHP/ref=cm_sw_r_cp_apa_i_y4JtCbQNHK1YX
It can easily help you center punch a shaft by finding the center. After that it is up to you to carefully drill out the center.
This has worked for me in the past.
From my experience, the hole in the center of 1/2" hex, churro, and round is usually not centered (visible w/o measuring), but its closer than just freehanding.
Do you guys have a cnc? We are going to use ours for getting holes in shaft.
No cnc:(
