What is important to remember is that the Operator Interface and Robot controller don’t read resistance, they read voltage. So when connecting a potentiometer you are really reading the voltage drop between the the wiper and the terminals A or B.
Ascii Art time:
A W B
You would connect positive to A and Ground to B. The input to the controller would be the Wiper (W).
You can turn the pot’s wiper, sometimes called the slider and vary the resistance between point A and W. To calculate the voltage drop you use Kirchoff’s Voltage Law.
R1 = Resistance between A and W in Ohms
R2 = Resistance between W and B in Ohms
V = 5V, which is supplied by the OI or RC
X = voltage drop across A and W
X = V * (R1/(R1+R2))
Example:
You are using a 100K potentiometer and it is turned about 3/4 of a turn. Let’s assume it is a single turn 360 degree pot. You whip out your multimeter and read 75K across A and W and 25K across
W and B. Using Kirchoff’s Voltage law the equation would be (X=5*(75K/(25K+75K))) which would equal 3.75 volts.
What does this mean to the programmers?
That voltage is sent through an ADC or Analog to Digital converter. The ADC has a resolutiuon of 10 bits (2^10 = 1024). That 5 volt signal is represented as a number from 0 to 1024. So what would our 3.75V potentiometer read like in your program?
V = input voltage
x = digital value in base 10
x = (V * 1024)/5
So for our 3.75V example: (x = (3.75 * 1024)/5), which equals 614. Your program would read 614 as the input if your 100K potentiometer was at 3/4 of a turn.
