Maple Sim Rotation Error
Error at java.base/java.lang.Thread.getStackTrace(Thread.java:1619): x and y components of Rotation2d are zero
    at edu.wpi.first.math.geometry.Rotation2d.<init>(Rotation2d.java:126)
    at edu.wpi.first.math.geometry.Rotation2d.rotateBy(Rotation2d.java:274)
    at edu.wpi.first.math.geometry.Rotation2d.plus(Rotation2d.java:213)
    at org.ironmaple.simulation.drivesims.GyroSimulation.updateSimulationSubTick(GyroSimulation.java:130)
    at org.ironmaple.simulation.drivesims.SwerveDriveSimulation.simulationSubTick(SwerveDriveSimulation.java:123)
    at org.ironmaple.simulation.SimulatedArena.simulationSubTick(SimulatedArena.java:336)
    at org.ironmaple.simulation.SimulatedArena.simulationPeriodic(SimulatedArena.java:311)
    at com.team5817.frc2024.Robot.simulationPeriodic(Robot.java:200)
    at edu.wpi.first.wpilibj.IterativeRobotBase.loopFunc(IterativeRobotBase.java:412)
    at org.littletonrobotics.junction.LoggedRobot.startCompetition(LoggedRobot.java:116)
    at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:419)
    at edu.wpi.first.wpilibj.RobotBase.lambda$startRobot$1(RobotBase.java:490)
    at java.base/java.lang.Thread.run(Thread.java:840)
I get this error and my simulated robot has nan components for translation
Hello!
The message you’re seeing appears when a Rotation2d object is initialized with a zero vector. It serves as a notification for users, but it will not cause your code to crash.
If your code is crashing, there is likely another issue at play. Otherwise, you can safely ignore this message.
