tried searching. did see it before what are the start times for each division?
thanks
Times won’t post until FMS run Event Wizard that will most likely be at some point in the day for when match start time
You do know that the tentative match schedules are already up, right? They’ll just have to confirm that everybody’s there. And if somebody isn’t there, then they get to re-run the schedule and mess everything up.
Looks like this will likely happen with Carson.
I never look at those because it never fails that a team or two don’t show up
True. But do you think that the start times will change much, if at all, from that? I don’t.
At the field we try to start on time or as close to it… I would say bet on it starting on time unless there is some problem at the field
Why?
It appears that 5931 has dropped, with 1625 filling their place.
Ah.
