Maxbotix MP1200, EZ0
We are using the proximity sensor Maxbotix MP1200 EZ0, and we are intending to use class ‘ultrasonic’. Does it help? Could you please show us the details?
Might not be Ultrasonic, but it depends on the programming language you are using.
LabVIEW has an operational example with a wiring diagram.
If you wire the Maxbotix for analog input (pins 3/6/7), then you just read the analog input and apply a conversion factor (.0049/cm or .012446/in I think).
