We got a HRLV-MaxSonar-EZ MB1013 in our KOP and I’m having a bit of trouble getting an actual reading from the unit. I’m powering it through the VMR 5V/500mA. I have the GND wired to Pin 7 and the live to Pin 6 as per the instructions. When I check the output of the analog pin I am getting a constant 4.68V when using a multimeter. When I hook it up the the analog input on the roborio I get about 4.5 (coding in JAVA using getVoltage()). This value does not change when objects are moved in from of the sensor at any distance.
Make sure to use something big to block the wall. Sometimes if you’re a couple of feet out a hand is not enough to trigger it unless you’re lined up well.
OK, Pin 6 is power (2.5 to 5.5 volts DC), Pin 7 is ground, and Pin 3 is Analog Output (referenced to Pin 7). With those 3 pins connected, you should see a varying DC voltage on Pin 3 as you place a (reasonably-sized) object in front of the sensor, about 0.001 volts per millimeter (4.88 mV/mm), minimum about 300 mm.
If all is correct and that’s not what you’re seeing, I claim faulty component.
