MAXSwerve Java Template v2023.1
We are trying to investigate our RevIon MAXSwerve drive. We are struggling because our Logitech F310 controller is new being interpretted incorrectly. It is supposed to be seen as an X-Box controller. The controller implements turning but not driving-propulsion. Mechanically, the driving and turning works through the REV-Client.
We can’t determine if it’s a programming issue or a wiring issue.
There’s a mechanical switch on the bottom of the F310 to switch between X-Box and DirectInput modes. Make sure it’s in the “X” position. https://www.logitech.com/assets/35017/gamepad-f310-gsw.pdf
Did that. What is weird is that the controller only controls the turning on the NEO-550s.
If the axes moves in the driverstation it’s not a controller problem
I do not know whether this helps, but our Scoot mini robot code is (mostly) working. It only uses 2 modules, but it is a modified version of the Rev Template. Arcade drive is working. The auto and field relative are not perfect yet, but we think it is a gyro (We are using a NavX2) or chassis calibration issue, not a module one.
