Hi there! Team 4663 here.
We’re trying to switch off from LabVIEW to Java for our main programming language, but we’re having some troubles. I used the Mecanum drive example code and edited it to work with our motor controllers, but the motors aren’t moving correctly. Can anyone help us out?
Pure Forward
R F
F R
Reverse
R F
R F
Strafe Right
F R
F R
Strafe Left
F F
F F
Rotate Right
F R
F R
Rotate Left
R F
R F
Here’s the Robot.java code:
// Copyright (c) FIRST and other WPILib contributors.
// Open Source Software; you can modify and/or share it under the terms of
// the WPILib BSD license file in the root directory of this project.
package frc.robot;
import com.ctre.phoenix.motorcontrol.can.*;
import edu.wpi.first.wpilibj.drive.MecanumDrive;
/** This is a demo program showing how to use Mecanum control with the MecanumDrive class. */
// private static final int kFrontLeftChannel = 2;
// private static final int kRearLeftChannel = 3;
// private static final int kFrontRightChannel = 1;
// private static final int kRearRightChannel = 0;
WPI_TalonSRX _talonFL = new WPI_TalonSRX(2);
WPI_TalonSRX _talonRL = new WPI_TalonSRX(3);
WPI_TalonSRX _talonFR = new WPI_TalonSRX(1);
WPI_TalonSRX _talonRR = new WPI_TalonSRX(4);
private static final int kLJoystickChannel = 0;
private static final int kRJoystickChannel = 1;
private MecanumDrive m_robotDrive;
private Joystick l_stick;
private Joystick r_stick;
public void robotInit() {
// TalonSRX frontLeft = new TalonSRX(_talonFL);
// TalonSRX rearLeft = new TalonSRX(_talonRL);
// TalonSRX frontRight = new TalonSRX(kFrontRightChannel);
// TalonSRX rearRight = new TalonSRX(kRearRightChannel);
_talonFL.configFactoryDefault();
_talonRL.configFactoryDefault();
_talonFR.configFactoryDefault();
_talonRR.configFactoryDefault();
// Invert the right side motors.
// You may need to change or remove this to match your robot.
_talonFL.setInverted(false);
_talonRL.setInverted(false);
_talonFR.setInverted(true);
_talonRR.setInverted(true);
m_robotDrive = new MecanumDrive(_talonFL, _talonRL, _talonFR, _talonRR);
//m_robotDrive.setRightSideInverted(false);
r_stick = new Joystick(kRJoystickChannel);
l_stick = new Joystick(kLJoystickChannel);
// Use the joystick X axis for lateral movement, Y axis for forward
// movement, and Z axis for rotation.
m_robotDrive.driveCartesian(l_stick.getX(), l_stick.getY(), l_stick.getZ(), 0.0);
Thank you!
