As mentioned in the original post, we now have our code on GitHub! Because we want to help as many teams as possible, we decided to do \mathfrak{both} the iterative and command-based Java paradigms. We have published two repositories for each type, and both will be functionally equivalent, meaning a driver wouldn’t know if the robot was running iterative or command-based. Here are the repositories:
Iterative: https://github.com/FAMNM/ri3d-2022-iterative
Command-based: https://github.com/FAMNM/ri3d-2022-command
You won’t be able to copy all of our code and run it, but certain parts can be used as reference. Key features:
Drive code with thresholding
We are using an XBox controller to drive the robot, and the joysticks aren’t perfect. They might drift from off-center slightly and make the drive motors twitch and stutter. We fixed this minor issue by setting the drive speed to 0 unless the absolute joystick reading is at least 0.05. An example of this can be found in \texttt{teleopPeriodic()} in the iterative code and in the \texttt{setSpeed()} method of the \texttt{DriveTrain} subsystem in the command-based code. This deadband can be increased or decreased depending on the quality of the controller.
Vision processing
To help ease the work of the drivers during the match, we would like the robot to assist in lining up with the cargo for pickup. This is a sort of computer-aided driving, where the robot controls the rotation speed and the driver controls the forwards and reverse speed. We are using a standard USB camera plugged into the roboRIO. The vision processing algorithm will detect the largest group of cargo-colored pixels and return which direction the robot needs to turn to line up with the target. The general pipeline from camera video to motor output is this:
- Grab the camera’s current frame and convert it from the RGB color representation to the HSV (Hue, Saturation, Value) representation. This makes it easier later to say “I want red-ish colors”. More information about the HSV representation can be found here: https://www.lifewire.com/what-is-hsv-in-design-1078068
- Perform a color mask. This procedure looks at each pixel in the image and determines if that pixel is cargo-colored or not. The robot’s needed cargo color can be automatically retrieved from the FMS (Field Management System) so that code won’t need manually changed between matches. The result of this operation is a new image where cargo-colored pixels are set to white and other pixels are set to black.
- Find the contours. This looks at the image as a whole and finds groups of white pixels (which represent cargo-colored regions) that are potential candidates for a target. This operation stores every contour into a list.
- Select the largest contour from the list. We iterate over the list of contours and select the one with the largest recorded area. Ideally this will be cargo, and the X and Y coordinates of this contour is recorded for use.
This process is found in the \texttt{nextVisionFrame()} method of the iterative code (which is called by \texttt{robotPeriodic()}), and is found in the \texttt{VisionProcessor} subsystem of the command-based code. Currently we are not using the outputs of this procedure is input for the drive train because our robot still needs some mechanical work, but we hope to incorporate it soon.
That’s all for now, if anyone has questions feel free to post them here!
