Microcontrollers
Is the use of a microcontroller allowed. In Update 4 it said that there could only be one control system. So can you use a microcontroller with the robot’s controller to make one control system or is it prohibited?
You can use a microcontroller as part of your custom circuit, as long as it complies with [rule=C29]Rule C29[/Rule]. With the restrictions of this rule, it is impossible to create a custom control system, so the ruling in update 4 is not really new.
So by the rule can a microcontroller read a signal from an output device and send it to the robot controller?
yes u can use a uP. U just can’t have it directly controll the speed controlers, etc.
*Originally posted by tbmantia *
**So by the rule can a microcontroller read a signal from an output device and send it to the robot controller? **
That is correct.
