Minibot Fuse
What type of fuse does the minibot battery fuse take? We misplaced our blown out fuse last night and need to purchase more as soon as possible.
A 20amp car fuse, go out to a car and look at it i believe they are normally yellow they are smaller than i dime. sorta triangle forks on the bottom
They use a 20 amp mini blade fuse like this one found at radio shack. http://www.radioshack.com/product/index.jsp?productId=2102773
They use a 20 Amp mini blade fuse like this one from radio shack http://www.radioshack.com/product/index.jsp?productId=2102773
They use a 20 amp mini blade fuse like this one at Radio Shack
One of those, a 20-amp mini-blade fuse as opposed to a standard blade fuse.
Earlier update allows for low amp fuses down to 3 amps…helps protect your dc motors, especially while you are testing your prototypes.
