I haven’t seen this question asked since 2012, so I thought it would be worth another inquiry. I have personally found inserting 18 AWG wire into Dupont housings to be quite difficult and 16 AWG to be nearly impossible because of the insulation thickness; I don’t know if that’s the nuances of the sizes or a consequence of our team lacking members with prior experience in electronics. Looking at the rules, I’m not sure exactly where the RSL fits into Table 9-4. Would 20 or 22 AWG be FRC legal? My current guess is that the RSL counts as a “SIGNAL LEVEL” circuit.
I’m going to go with “keep reading”. This one took me a bit.
R709 covers wiring the RSL, and its blue box links to How to Wire an FRC Robot — FIRST Robotics Competition documentation. Which, if you scroll down, says to use 18 AWG. Drat.
Table 9-4, Signal Level circuitry: “(i.e. circuits which draw ≤1A continuous and have a source incapable of delivering >1A, including but not limited to roboRIO non-PWM outputs,”, 28 AWG minimum.
Hmm… and the spec sheet for the RSL says it’s a 12VDC 60mA continuous draw.
Of course, 28 AWG being the minimum you could always bump up to say it’s on a <=10A Fuse protected circuit (which it is, RoboRIO uses 10A) and that’ll give you 22AWG.
So, long story short: 22AWG gives you two rules you’re safe under, anything smaller leaves you with 1. 20 AWG is just extra safety compared to 22 AWG.
There is no wire size limit in the robot rules for RSL. The connector on the Roborio is the same spacing as the PWM connectors but it is a two pin connector. It is easy to modify a premade PWM connector to wire the RSL. The connector at the RSL is meant for #18 or smaller so #22 is perfectly fine.
We wired ours today with what is most likely 22 AWG (it’s a red/black cable with 0.1" spacing ends on it, that came in the REV cable kit) . Just like we’ve done for years.
