Mismatch of controller and motor?
I will be part of the beta for the Studica training robot (https://www.studica.com/frc-training-bot.html). My goal right now is to do a from scratch design of shooter mechanism for ping pong balls, that I can mount on the chassis, with the idea of using that as a training platform for two teams, in using CAD, , doing mechanical design, electrical design, and FRC/WPIlib programming in prepartion for next season.
I am trying to strike a balance between staying within the wpilib family of motor control drivers, explore CAN based wiring and PID, while at the same time, work within a smaller, lighter, lower cost physical set of actuators.
The specific question I have is about using a Spark MAX (https://www.revrobotics.com/rev-11-2158/) to drive a Pololu DC brushed motor (https://www.pololu.com/product/4757) with a built in encoder. The motor takes a 12V input, but obviously the power usage is significantly lower than your average CIM motor.
My question is, can I combine the more capable/powerful controller with the smaller guage motor without blowing something up?
TIA,
Charlie Peppler
Yes, you definitely can. The controller only provides as much current as the motor ‘asks’ for, which on a 12v system like it’s designed for, will be the same as expected.
