We are using motion magic with arbitrary feedforward for our arm with a custom gearbox, and the arm moves fine, but when it gets into position (horizontal) it stalls. The current draw on the falcon is around 3.75. We apply a varying FF depending on the angle, but when we set a constant FF of 0.07 (7%) the output of the motor is ~5%, and no matter how much we change the FF it is always that amount, even if we set an extreme large FF. Motion magic seems to be ignoring feedforward commands.
Can you share your code?
Do you have current limiting enabled?
We are not using any form of current limiting; the motor doesn’t need to draw a lot of current to hold its position due to such a large gearbox reduction. We call set(ControlMode.MotionMagic, position, DemandType.ArbitraryFeedForward, demandFF)
when we set a new position. We have good acceleration and cruise velocity configs with good movement. The motor should just be holding its position without making that whining noise.
