We have an arm using MotionMagicTorqueFOC and I just want to confirm what reference point should be provided. We expect it to be -1 to 1 where 0 is the position forward horizontal. Is this accurate?
We are seeing weird motion and when the motion is complete the mechanism isn’t being held at position even with some P. Is that expected?
MotionMagicTorqueFOC doesn’t have a feedforward. It has a kA, kV, kS, and a kG. We have all of these values set. We got these values from SysID (with some messing around since there wasn’t a lot of data). Overall the motion is actually quite good 90% of the time. But 10% of the time it just doesn’t work right and it doesn’t really hold position.
public static final Slot0Configs pivotGains = new Slot0Configs() {{
GravityType = GravityTypeValue.Arm_Cosine;
kS = 1.6221;
kG = 2.3923;
kV = 1.6429;
kA = 2.7332;
kP = 69.657;
kI = 0;
kD = 26.77;
I know, but then why is it feedback? I accidentally referred to kG as only the one for arm.
For elevator type feedback it should be setpoint * kG, which still isn’t feedback.
But then it creates some kind of way where if you drift a bit you’ll keep drifting since everytime you slightly change your angle that’s the new “setpoint”. So it’ll create drift over time if your values aren’t perfect
They were the result of using SysId with Torque as voltage. I agree that some of thes should be 0 but ot is what it provided and it actually functions. It just isnt as accurate as we want. When we tried to maually tune it we had all sorts of problems.
SysId doesnt really work well with arms that mobe fast and dont move far. We had to do multiple tests to get data that would result in valid kv, ks, etc.
If you have suggestions on how to run tests that would work better that would be great!
Now that the mechanical issue is resolved we are trying to redo SysId and it is really tough. I think the problem is that it is including more data that we want into the test.
I don’t think the fix has hit a release yet, unfortunately, so you either have to copy the code into your own repository or else roll the dice until the test works (I recommend the former).
In any case, it looks like your signal is extremely noisy. I’d look into that.
Do you have any suggested resources on the data being noisy? We are currently using the ctre SignalLogger and we have increased the data to 250 hrtz. This was based on examples from ctre.
