Motor Buttons
HI!!
How do I program a motor to a button? We have always used axis for motors and don’t know how to use buttons for the motors. Could someone post code so I can see how it is done?
Thanks in Advance 3750!!
you have to use an index array connected to button wires then add a constant for the button (0 btn 1,1 btn 2,etc) I hope this helps we are stuck on pneumatics which is farther along
:slight_smile: :slight_smile: :slight_smile: :slight_smile: :slight_smile:
You have to decide what you’d like the motors to do.
Here’s one way:
It looks something like this:
x=isbuttonpressed();
if(x) {
setmotorspeed(SPEED);
} else {
setmorospeed(0);
You need to put in the code for checking to see if the button is pressed, and how to set the motor speed for your motors.
FYI this is in the Labview sub-forum.
